help me plz - A 3x3 keypad doesn't work.
Discussion in 'The Projects Forum' started by jacobd12, Jan 27, 2016.
  1. jacobd12
    Jan 27, 2016
    I am designing a keypad on circuit wizard. The diagram works fine , however when I use copper tracks and flying wires on my PCB version it does not work please help!!
    This is the keypad wired
  2. RichardO
    May 4, 2013
    1,342
    431
    What switch are you using? Most switches like like the one you show have a short between pairs of pins to make it easy to do a single sided PCB.
    My guess is that you have the switch wired such that the internal switch connections are causing shorts in your circuit.
    jacobd12 likes this.
  3. Dodgydave
    Jun 22, 2012
    5,159
    772
    What's happening then, what is or isn't working?
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    As said, there are two pairs of contacts.
    Have a look at the following picture:
    Bertus
  5. jacobd12
    Jan 27, 2016
    Thank you everybody! I had orentated the switches the wrong way and was shorting out my whole circuit,just yad to flip them all round in the side.
    Thanks again!
  6. jacobd12
    Jan 27, 2016
    Whole keypad*
