help me pls in AT89S52 programming p
Discussion in 'Embedded Systems and Microcontrollers' started by mohlandmine, Aug 16, 2009.
  1. mohlandmine
    May 2, 2009
    hi all
    i use AT89S52 which is 8051 micro
    i interface the micro woth M74HC151B1 to increase the number of input pins
    now how i can demultiplexing the 8's inputs internal the micro itself
    and how i generate the three addresses to select the first input to go to the micro then the second and so,on 0101010101..../001100110011..../000111000111.... continuaslly
    pls see the M74HC151B1 datasheet to now what i mean
    thanks
    who help aothers he help himself
  2. mohlandmine
    May 2, 2009
    noooooo helpers here?
  3. rushi53
    Member
    May 8, 2009
    21
    Connect Pin 9, Pin 10, Pin 11 of Multiplexer to Any port of Microcontroller
    These are A B C pins of Multiplexer
    Please let me know if you need any help
    __________________
    Thanks,
    Rushikesh
    www.projectsof8051.com
