help me please.....
Discussion in 'Homework Help' started by xinzlee, Dec 3, 2007.
  1. xinzlee
    Nov 19, 2007
    13
    How to design with using several two input NAND gates to implement the function F=A+B+C............
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Double NOT the function, and use DeMorgan's theorem to change the expression from OR to AND type. If you tie the inputs of a NAND gate together you get a NOT gate.
    Dave
  3. !!Miss.EE!!
    Oct 17, 2007
    38
    design it with OR gates first then redesign it with NAND.
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    That is essentially what you are doing with DeMorgan's theorems.
    Dave
