Help me please ?..
Discussion in 'Programmer's Corner' started by ghaya, Apr 15, 2012.
  1. ghaya
    Apr 15, 2012
    Hi.. :confused::(
    I Take Microprocessor and firmware and I have some problems
    i have 3 Q
    1- Write the code for an algorithm to replace the most frequent element in the matrix with the geometric mean of its diagonal.
    2-Find the largest palindrome made from the product of two 3-digit numbers.
    3-What is the smallest number divisible by each of the numbers 1 to 20?
    all we need to write the code for them :( i solved 7 Q but this 3 i can't
    Help me :(
    thank you .. :confused:
  2. panic mode
    Oct 10, 2011
    1,328
    305
    geometric mean of diagonal is sqrt(a11*a22*a33*a44...)
    to find which element is most common, you need to count occurrence of each value.
    then go through matrix and do replacements
    palindrome is number or word that reads same way forward and backwards.
    brute force method works too, find products of all 3-digit numbers until you get palindrome. i'd start from large numbers because we are looking for max product.
    factor all numbers 1..20, remove redundant factors and multiply the rest.
