help me please
Discussion in 'General Electronics Chat' started by ksalatawi, Nov 29, 2004.
  1. ksalatawi
    Nov 29, 2004
    21
    I have project about op-amp and i want you to help me please i but the question in attachment with the message
  2. pebe
    Oct 11, 2004
    628
    I may have missed something, but I think the circuit cannot work.
    The amp needs a gain of 2 to amplify a 5v swing on the input to a 10v swing at the output. This gives a value of 10k for Rf. With a bias of 2.5v on the +input, the amp output would invert the input change and swing between -2.5v and +7.5v With the 2.5v offset provided by the battery at the output, Vo would then swing from -5v to +5v. So far, so good.
    The trouble is the supply+ rail is only +6v and so the output cannot possibly swing to +7.5v.
    It would work with a +-9v supply, though.
  3. ksalatawi
    Nov 29, 2004
    21
    thank you
    but still the graph how ican draw it
  4. pebe
    Oct 11, 2004
    628
    Graph for Vg/Vo
    Let x be the input voltage and y the output voltage.
    Scale the graph as x = 0 to 5, and y = -5 to +5
    Draw a straight line from 0x/+5y to 5x/-5y
    That is how the graph *should* look except for the supply rail problem.
    With the limitation of the 6v positive supply rail, the slope cuts off at approximately +3.5y, so draw a line from 0x/+3.5y to 0.75x/+3.5y
  5. ksalatawi
    Nov 29, 2004
    21
    thank you very much
  6. ksalatawi
    Nov 29, 2004
    21
    what is the equation of the diagram
  7. pebe
    Oct 11, 2004
    628
    Vo=5-2(Vg)
  8. ksalatawi
    Nov 29, 2004
    21
    thank you very much
  9. dragan733
    Dec 12, 2004
    152
    The schematic is Ok. On the output of the opamp is 7,5V as a result of the sum of signals Vg on the - , and the voltage 2,5V of the + of the opamp.
    Then:
    Vo= - (Rf/5)Vg + (1+Rf/5)2,5 - 2,5
    Vo=(Rf/10)(5-2Vg)
    For: Vg=5V, Vo=-5V, then: Rf=10K
    or, for: Vg=0V, Vo=5V, then: Rf=10K,
    then:
    Vo=5-2Vg
  10. dragan733
    Dec 12, 2004
    152
    Yes, the power supply is not good
    Or to explain better the schematic.
    The Output voltage is:
    Vo=5-2Vg
    The Output voltage of the op amp is:
    Vop=7.5-2Vg
    For the range of the voltage: Vg=(0-0.75V) the Output voltage of the op amp is alvays 6V, then Vo=4.5V
    In the attachment one can see the results graphic
