Help me! Phase shifter using OTA..
Discussion in 'The Projects Forum' started by Yuva Phani, Sep 30, 2015.
  1. Yuva Phani
    Sep 30, 2015
    5
    I am currently pursuing my BTech. I want to do a project on 90 Degrees phase shifter for wide band ranging from 100HZ to 10MHZ using orthogonal transconductance amplifier. For any frequency in that range, the phase shift must be 90 degrees(might not be that accurate). Any suggestions, On how to proceed and implement it. Thank you in advance.
  2. blocco a spirale
    Jun 18, 2008
    1,463
    372
  3. dannyf
    Sep 13, 2015
    2,196
    417
    You are the 2nd guy over the last 24-hours asking for the same thing.
    Did you guys go to the same school or work on the same assignment?
  4. Yuva Phani
    Sep 30, 2015
    5
    Nope...i dont know him...Do u have any suggestions for me, on how to proceed...?
  5. atferrari
    Jan 6, 2004
    2,674
    785
    Does it exist really? Myself, for the acronym in the title, I expected a more conventional translation.
  6. blocco a spirale
    Jun 18, 2008
    1,463
    372
    If you present what you've got so far, you might get a better response.
  7. The Electrician
    Oct 9, 2007
    2,301
    339
    Yuva Phani likes this.
  8. Yuva Phani
    Sep 30, 2015
    5
    Thanks Electrician..It is helpful..
    sorry Atferrari...It is Operational Transconductance amplifier...pardon me :)
  9. DickCappels
    Aug 21, 2008
    2,789
    677
  10. Yuva Phani
    Sep 30, 2015
    5
    Thanks DickCappels :)
    I am already working on it. Can u help for higher frequencies i.e 1 MHz to 10 Mhz using ota.
    Thanks in advance
  11. crutschow
    Mar 14, 2008
    13,523
    3,392
    Is this a wide-band signal or a single frequency signal (at any instant in time).
  12. Yuva Phani
    Sep 30, 2015
    5
    Wide-band signal
