help me i need guage ratio formula
Discussion in 'General Electronics Chat' started by adeel, Jul 2, 2008.
  1. adeel
    Jun 28, 2008
    16
    hi , Friends i am very happy to see all replies but i really didn't understand i mean need a formula for example if i use 22 guage primary then what should be the guage for secondary is there any accurate formula i visted page http://www.powerstream.com/Wire_Size.htm here i found
    Maximum amps for power transmission = 0.92 and
    Maximum amps for chassis wiring = 7
    i am surprised what is actually 22 guage wire can bear in a transformer i mean is it 7 or 0.92 :confused:
    and if i used 12 guage wire for secondary then for it is it 41 amps or 9.3 amps
    friends i really need a formula like for guage of primary wire , guage of secondary should be . i am not good in electronics . help me friends thanks:)
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Transformers can handle some maximum amount of power. While there are some losses, the power in the primary is about the same as power in the secondary. Here is the article in out Ebook that discusses transformers - http://www.allaboutcircuits.com/vol_2/chpt_9/2.html.
    Notice that you have to know if the transformer is stepping up the voltage, or stepping it down. If it is stepping down, then current in the secondary will be greater than in the primary so the product of voltage and current will be the same. In that case, the secondary wire gauge will be larger than the primary.
    For a good answer to your question, we need to know the transformer power, it's primary voltage, and the secondary voltage.
  3. adeel
    Jun 28, 2008
    16
    hi , thanks a lot for replying well detail for transformer is
    primary voltage = 220
    secondary voltage = 24
    frequency = 50/60 hz
    now problem is that i don't know guage ratio i know formula for turn ratio like
    Vp/Vs = Np/Ns
    but for guage i have nothing i visited page http://www.powerstream.com/Wire_Size.htm
    where Maximum amps for chassis wiring are different and Maximum amps for power transmission are different i am totally confused i mean i my transformer is ideal and i used 22 guage magnetic wire for primary then amp it can bear according to table is 0.92 and thus
    p= 220 * 0.92= 202.4 va and for secondary i have 24 volts thus i used 12 guage magnetic wire then
    p= 24*9.3 = 223 va
    is it right what i am calculating or totally wrong
    last time i opened a good transformer i measured the gauge of primary it was 21 then i calculated va rating of transformer and it was
    p= 1.2 * 220 = 264 va which is totally wrong rating mentioned on it was 1000 va . help me .
    i need a good formula by using which i can wind a transformer like if primary is 22 guage what should be the guage of secondary . and if i use 24 guage primary then guage of secondary and so on ??????? help me friends please. thanks
  4. adeel
    Jun 28, 2008
    16
    Vp/Vs = Np/Ns
    p= 24*9.3 = 223 va
  5. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
  6. silvrstring
    Mar 27, 2008
    159
    22 gauge would be limited closer to .9 A---not 7 A. And 12 gauge is rated for 9A, not 41 A. 7 Amps would require 13 AWG, and 41 Amps would require 5 AWG.
    A safe formula that might help is AWGsize = 50 - 10*log(700*I) where I is current, of course. Round your answer down to the next whole number (e.g., 5.42 to 5).
    Likewise, if you already have an AWG wire size but would like to know its current carrying capacity (safe), I = [10^((50-AWG)/10)] / 700. You could just look at the tables, but math is more fun.
    As you can see, the formula and the AWG scale are logarithmic. I don't think you will find a formula as simple as the turns ratio formulas.
    For your second power calculation, I think you used 9.3 A because that is what 12 AWG is rated for. But Is/Ip = Np/Ns = Vp/Vs, and I got 8.43 amps which in turn gives a power rating of 202.4 VA. Stick with the lower calculation, not the 223 VA. 12 AWG winding is still good for 8.4 A, though.
  7. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  8. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Oh, and please refrain from posting multiple identical topics. Thank you.
