Help me,I need a circuit design
Discussion in 'Homework Help' started by maxspot, Mar 15, 2011.
  1. maxspot
    Mar 15, 2011
    Greetings,
    i need a help from you genius,
    the requirement is simple,there are two lights(Green and Red) ,IN NORMAL STATE Red is alway ON Green is OFF positions. If i involve this circuit with push button switch ,state should change to reverse mode for only 5 to 10 seconds, then should go to normal mode.
    please give a circuit diagram - the load of the light shall be 20W.(Min)
    i need to submit
    Thank you lot.
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Wrong section, should be in homework help.
  3. R!f@@
    Apr 2, 2009
    8,792
    771
    U draw one and we will help in correcting it....we do not spoon feed anyone.
    By the way..Welcome to AAC
  4. majsyd2010
    Member
    Aug 29, 2010
    61
    I have sent you an email with circuit diagram, Please have a look as see if get it, For some reason, I couldnt find how to attached the file through this, and if you know how to, Please attach the file so other poeple can view too ...
    Cheers & Good luck with homework
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    @ majsyd2010 ,
    This homework section is NOT for giving the complete answers.
    You may give hints and directions for solving the problem.
    Bertus
  6. majsyd2010
    Member
    Aug 29, 2010
    61
    Oh My apology ... promise wont happen again ...
    Cheers,
