Here's what it looked like when i opened it up.
So I cleaned it with alcohol and heated it with a heat gun on medium heat for 40 min.
There's still a short somewhere on the mobo. This is where i believe the short to be since it was sticky and black in that area. I used a multimeter and check continuity on the components in the area, with them still on the board.
I'm not really sure where black gunk came from. I got the mobo like that.
I tried plugging it in and it's still short.
When i put the multimeter on the most gunked up button switches the meter shows a short. The other button switches don't show this. I guess the button switches themselves could be the short? Or maybe this caused one of those little things to blow?
Should i try taking the shorted buttons off and than seeing if it's still short without any button on it?
