help me find these banana plugs
Discussion in 'The Projects Forum' started by elimenohpee, May 29, 2011.
  1. elimenohpee
    Thread Starter Active Member
    Oct 26, 2008
    47
    So I'm converting an old power supply to a work bench with easy access to 5V, 3V, and 12V rails. My only problem at the moment is finding the plugs the banana cables will fit into. Here is a link to the project I'm doing:
    http://www.mbeckler.org/powersupply/
    I believe these connectors are called binding posts? Will these work?
    http://www.newark.com/cliff-electronic-components/tp1-red/terminal-4mm-panel/dp/75R3344
    I do not know the size of banana plugs, so I just wanted someone who has possibly worked with these before to check and make sure I have the right component picked out.
  2. #12
    Nov 30, 2010
    16,705
    7,355
    I think they will work, but "I think" isn't good enough when considering the $20 handling fee. I suggest you use the "ask a question about this product" just above and to the left of the picture.
  3. TBayBoy
    Member
    May 25, 2011
    148
    19
  4. CDRIVE
    Jul 1, 2008
    2,223
    99
  5. someonesdad
    Jul 7, 2009
    1,585
    141
    Almost certainly you want the standard 4 mm banana jacks. Space them at 3/4" (19 mm) and you can then use e.g. BNC to dual banana adapters to let you use coax cables if you want. There used to be smaller mini-banana plugs, but I haven't seen any in many decades. Other sources are Pomona Electronics (bought by Fluke) and Cal Test Electronics. I prefer to use the dual binding posts so that the 3/4" spacing is a given.
  6. CDRIVE
    Jul 1, 2008
    2,223
    99
    That's a good point. The other thing I like to see on a banana binding post is the jack contacts NOT buried nearly a half inch below the mouth of the insulation. It makes for a royal peta if using small alligator clips.
  7. elimenohpee
    Oct 26, 2008
    47
  8. #12
    Nov 30, 2010
    16,705
    7,355
    Most of my binding posts live without the plastic nut because I use alligators, too. Nobody actually clenches a wire with the nut if they have alligators or banana plugs.
