help me find schematic diagram for amplifier
Discussion in 'The Projects Forum' started by aclefriveo, Jul 18, 2008.
  1. aclefriveo
    Jul 18, 2008
    do you have schematic diagram for an amplifier that has maybe 1000 watts of amplification or higher
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    No, sorry.
    What would you do with an amplifier that powerful?
  3. mozikluv
    Jan 22, 2004
    1,437
    you can search for a 250w audio ic say from sanyo (that is if they still make those) their STK series, then do a bridge/parallel circuit. this way you ran them cooler. if ever you will build this, you must have an output ballast resistor to make it work well. however to further enhance its performance (not necessarily increase output)a servo circuit is recommended. this way you minimize the output offset voltges that causes inequalities in its output voltage.
    is this for commercial purpose?
    moz
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
