Its not smd its a through hole component recovered it from cooler master 500 watt power supplyIs this a SMD component? Those can be tricky to identify. But if you can take a picture of it. It will help a lot
I see..But anyway if you can take a picture of the diode and the circuit board so we can see diode in full circuit it may help. I take it for granted that you have done a search on Google. However some manufacturers use custom labeling. So Google may in some cases be dead endIts not smd its a through hole component recovered it from cooler master 500 watt power supply
Now that we are at a dead end, maybe you can trace the circuit to get some more info.
A photo of the board?
Name, Model of the Unit?
Ramesh
by Aaron Carman
by Aaron Carman
by Dale Wilson
by Duane Benson
