If the load is 7 amps or less, that is adequate. However, it would be best if the load was 3.5 amps or less.I'm confuse
is that enough to switch 220vac line?
What is the load connected to the relay contacts?
What is the relay model or did you buy the 12V 45Series that you previously described?
