Please help me design offset voltage compensation to adjust V0 to zero when Vi=0
Thread Starter Đức Thanh Joined Jun 10, 2015 2 Jun 10, 2015 #1 Please help me design offset voltage compensation to adjust V0 to zero when Vi=0
#12 Joined Nov 30, 2010 18,224 Jun 10, 2015 #2 Simple method: Buy an op-amp with adjustment pins provided and follow instructions on its datasheet.
Thread Starter Đức Thanh Joined Jun 10, 2015 2 Jun 10, 2015 #3 this is a excersice,so i dont know how to draw circuit.
AnalogKid Joined Aug 1, 2013 10,987 Jun 10, 2015 #4 If you don't know how to draw a schematic, how do you plan to present your result? ak
WBahn Joined Mar 31, 2012 29,979 Jun 10, 2015 #5 MOD NOTE: Merged two threads that pretty clearly were meant to be the same thread.
DickCappels Joined Aug 21, 2008 10,152 Jun 11, 2015 #6 If you read a datasheet for an opamp like the TI OP-07 that has offset adjustment pins as mentioned by #12, you can learn how to adjust the offset. It is pretty simple. www.ti.com/lit/ds/symlink/op07c.pdf
