help me! about Matlab
Discussion in 'Programmer's Corner' started by masteroind, May 14, 2011.
  1. masteroind
    May 14, 2011
    I have a problem with this file that I have wrote it
    clear
    fid=fopen ('dusss.txt');
    A=fscanf(fid,'%g%g%g%g',[4 inf]);
    fclose(fid);
    clc
    B=load('dusss.txt');
    for i=1:17;
    Result(i,1)=B(i,2)+B(i,3)+B(i,4);
    if Result(i,1)>79
    G(i,1)=A;
    elseif Result(i,1)>74
    G(i,1)=3.5;
    elseif Result(i,1)>69
    G(i,1)=3;
    elseif Result(i,1)>64
    G(i,1)=2.5;
    elseif Result(i,1)>59
    G(i,1)=2;
    elseif Result(i,1)>54
    G(i,1)=1.5;
    elseif Result(i,1)>49
    G(i,1)=1;
    else
    G(i,1)=0;
    end
    end
    S=[B Result G];
    disp(' code F.test S.test Final test total Grade')
    disp(' 30% 15% 50% 100%')
    disp(S)
    When I run this file why the result be like this
    30% 15% 50% 100%
    1.0e+007 *
    4.9024 0.0000 0.0000 0.0000 0.0000 0.0000
    4.9026 0.0000 0.0000 0.0000 0.0000 0.0000
    4.9029 0.0000 0.0000 0.0000 0.0000 0.0000
    4.9037 0.0000 0.0000 0.0000 0.0000 0.0000
    4.9048 0.0000 0.0000 0.0000 0.0000 0.0000
    4.9075 0.0000 0.0000 0.0000 0.0000 0.0000
    5.0013 0.0000 0.0000 0.0000 0.0000 0.0000
    5.0015 0.0000 0.0000 0.0000 0.0000 0.0000
    5.0017 0.0000 0.0000 0.0000 0.0000 0.0000
    5.0018 0.0000 0.0000 0.0000 0.0000 0.0000
    5.0025 0.0000 0.0000 0.0000 0.0000 0.0000
    5.0032 0.0000 0.0000 0.0000 0.0000 0.0000
    5.0033 0.0000 0.0000 0.0000 0.0000 0.0000
    5.0034 0.0000 0.0000 0.0000 0.0000 0.0000
    5.0053 0.0000 0.0000 0.0000 0.0000 0.0000
    5.0059 0.0000 0.0000 0.0000 0.0000 0.0000
    I want it be like this
    code F.test S.test Final test Total Grade
    30% 15% 50% 100%
    49024226 30 12 44 86 4
    49026308 32 10 8 50 1
    49028593 25 5 40 70 3
    49036559 23 7 33 63 2
    49037376 31 7 18 56 1.5
    49047654 25 3 35 63 2
    49074579 34 7 20 61 2
    50012883 31 7 34 72 3
    50014643 34 7 15 56 1.5
    50017453 35 8 7 50 1
    50018263 28 7 35 70 3
    50024832 34 9 27 70 3
    50032381 32 7 21 60 2
    50033242 33 7 13 53 1
    50034285 27 5 40 72 3
    50053497 35 9 18 62 2
    50058889 29 7 30 66 2.5
    I need you to fix this one as soon as you can, thank you every much
  2. steveb
    Jul 3, 2008
    2,433
    469
    Look up help on the following commands: format, int8, int16, int32, uint8, uint16 and uint32.
    You basically have an issue with formatting of the displayed output.
    if you use the "format long g" command you will allow the full double precision values to be displayed, rather than the truncated values you see. Also, your first column appears to be an integer value (I'm not sure), and if so, you may want to convert the value to integer before displaying it.
  3. steveb
    Jul 3, 2008
    2,433
    469
    Note, you may also want to look into the sprintf and fprintf commands which allow printing to files and to strings with better formatting control. Just dumping an array to the screen is somewhat limited. The issue is that your first column has so many numbers, and the other columns don't.
