Machine breakdown
1)Previously, the machine condition is ok but after our 3 phase induction motor problem we replaced it. the problem is the ammeter to show the value if motor start up is not going up. this machine use 2 induction motors 3 phase. only one motor will show the value at ammeter. I suspect the current transformer problem so I swap it then the value going up. But after I buy new current transformer and change it still have the same problem. the worst case 2 motors not showing any value ammeter when the motors turn ON.I already try to change other phase but it can on 1st try but after that still same problem. Can anyone help me?? Thank you.
