help making a circuit board
Discussion in 'The Projects Forum' started by markosillypig, Mar 29, 2010.
  1. markosillypig
    Thread Starter Active Member
    Jul 21, 2008
    184
    hi all i have tried lots of programs for making circuit boards and they still dont work for me could any one make me a circuit board template as i have tried so many times without sucsess
    thanks
    pic of scamat included
  2. shortbus
    Sep 30, 2009
    4,095
    1,681
    In any of the PCB circuit software, you have to first reproduce your schematic in the software "schematic capture". You don't just start off with the "PCB maker" part of the software.
    Hope this helps.
  3. BMorse
    Sep 26, 2009
    2,675
    234
    Actually, you can just jump right into making the PCB without a schematic, but there will not be any error checking.... (I do this all the time in Eagle and in Express PCB), But it is highly recommended that the OP start with a schematic since it would be easier to check netlist errors and such...
    B. Morse
  4. John P
    Oct 14, 2008
    1,638
    225
    No, that isn't necessarily true. You could make a PCB design by laying out the circuit "free hand" if the software allows it. Obviously it's a risky procedure, but if the circuit is simple it would have a chance.
    Try FreePCB:
    http://www.freepcb.com/
    If this is one that you've tried and failed with, then all I can say is you haven't tried very hard. It's dead simple.
    Edited to say: My reply was directed at the original message, not BMorse.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  6. markosillypig
    Jul 21, 2008
    184
    HI Thanks sgtwookie for the advice i managed to do it
    just wondered if some one could check it to make sure it is ok
    i'm going to mount the to3 on the outside of the box
    tp9/7/6 or for the to3 tp3/4 are for the vcc+ and -
    thanks
    marko
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You might find the video interesting - http://www.edn.com/blog/1700000170/post/30053603.html?nid=3351&rid=16356411
    I have this thing about threading traces between pads, unless really necessary. The attached layout is a suggested alternative. Notice I used a cheapo FET in place of those two transistors. I see I left off the 220 μF cap, but by accident.
    The component J1 is a zerohm resistor. A clipped resistor lead will work as well as a jumper.
  8. markosillypig
    Jul 21, 2008
    184
    where does r2 conect to ??
    looks like a good alternative to what i have been using will give it a try thanks
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That was clever of me - R2's open pad should attach to the +12 volt trace. Sorry.
  10. markosillypig
    Jul 21, 2008
    184
    like this ????
    thanks
    again
  11. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That is correct.
  12. markosillypig
    Jul 21, 2008
    184
    what is the polarity of the irf530 ??
  13. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It's an N channel FET. Google the name to find a data sheet. Just about any TO-220 package FET should work. I selected that one because of availability and it's cheap. An IRF510 or 520 would probably do as well.
