HELP! Magnet activated circuit
Discussion in 'The Projects Forum' started by Tanno_uk, Jun 6, 2011.
  1. Tanno_uk
    Jun 6, 2011
    Hi all!
    I am completely new to electronics but very keen to learn. I want to make a circuit which activates an alarm or light when a magnet passes through it. It is for a device I would like to make
    Would this be complicated?
    Any advice would be greatly appreciated
    Thanks all!
    Chris
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Depends. Know what a reed switch is? It is used for alarms on houses a lot. If there is a magnet close it is closed, if not it is open.
    There are fancier, more sensitive setups out there, but this is a start.
  3. Tanno_uk
    Jun 6, 2011
    And by closed does that mean the alarm/light would come on?
    What other components would be needed?
    Sorry about my lack of even basic knowledge but I really am just starting now?
    Also, where is best to buy these components from? Can you recomend an online source?
  4. Bernard
    Aug 7, 2008
    4,232
    414
    " The Electronic Goldmine " has Reed switches, # G1347, G16648, Burgler Alarm Kit # C6280; also Hall Effect SW #G1994. For a door alarm,normally open reed SW is attached to frame & magnet to door, so that wheen door is closed the SW is closed, alarm sounds when door & SW open. The Hall SW acts like a transistor which is activated by magnetic field instead of base current.
