Help: LM386N Amplifier
Discussion in 'The Projects Forum' started by angads25, Jun 20, 2014.
  1. angads25
    Jun 20, 2014
  2. Dodgydave
    Jun 22, 2012
    5,159
    772
    So whats the problem then?
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,705
    1,300
    No. How about this: you go through the link, think about what it says, think about what you want to know, formulate a question, and then ask that question. Include a schematic.
    ak
    angads25 likes this.
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    trying to use an lm386 for a phono amp isnt a good idea. most phono pickups today are dynamic, and have very low voltage outputs. use a preamp.
  5. wayneh
    Sep 9, 2010
    12,396
    3,246
    The OP authored the link and has received the answer there. I'd say this is done unless he comes back.
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Cross posting... Grrr.
    "I'm so useless and lazy I can't be bothered cutting and pasting the same question in two places, so just go to this other link and help me". :(
  7. angads25
    Jun 20, 2014
    The problem isnt solved....and from next onwards i will try to put as least links as possible.....and no cross posting....
  8. tracecom
    Apr 16, 2010
    3,879
    1,396
    Most "instructables" aren't very instructive. Why don't you simply state what you want to accomplish, and someone here will likely be able to help. For example, here is a project that I completed using the LM386. The design is largely taken from the LM386 datasheet (which you should download and read.)
  9. angads25
    Jun 20, 2014
    I want to make an amplifier for my guitar....
  10. MrChips
    Oct 2, 2009
    12,648
    3,458
    LM386 would be a poor choice for a guitar amplifier.
  11. angads25
    Jun 20, 2014
    :/..... Hmm....any easy diy to make one....??
  12. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    For some Audio Amplifier projects, you could look in the "Completed Projects Index":
    Bertus
  13. tracecom
    Apr 16, 2010
    3,879
    1,396
    The LM386 will not make a great guitar amp, but it will make a decent practice amp if you add a preamp stage to the front end. Read this thread and you will find the details of one that I built, which worked fairly well for practice.
  14. MrChips
    Oct 2, 2009
    12,648
    3,458
