help:LIS302DL free fall detection
Discussion in 'The Projects Forum' started by alexpanrui, Jan 14, 2009.
  1. alexpanrui
    Thread Starter Active Member
    Feb 25, 2008
    32
    what is the practical use of free fall detection? I downloaded one app notes on lis302dl, in which the pseudo code of free fall detection is given. I coded it and released the sensor from certain height. According to the explanation of the pseudo code, an interrupt should be generated when free fall detected. But I was unable to receive the interrupt signal. What could go wrong?
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Which app notes? Can you provide a link?
  3. RiJoRI
    Aug 15, 2007
    536
    26
    "What is the practical use of free fall detection?"
    (A) to idiot-proof skydiving?
    (B) to allow the military to drop supplies to troops with less time of descent and/or less drifting?
    --Rich
  4. davebee
    Oct 22, 2008
    539
    46
    After you drop your laptop, to move the hard drive head quickly to an edge of the platter for protection before the laptop hits the ground?
  5. kubeek
    Sep 20, 2005
    4,691
    806
    Yes that is the only (pracitcal) use that came to my mind.
    Or could be used to activate airbags when you drive off a cliff :)
  6. alexpanrui
    Feb 25, 2008
    32
    file attached.
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I would guess that with a selection of +/- 2 & +/- 8 G's, the zero G level is actually 1 G - normal gravity. That would make the measurement relative to that, or +3/-1 G actual.
  8. alexpanrui
    Feb 25, 2008
    32
    in the pseudo code given in the app note, a threshold and a duration have been set.And the interrupt is activated if the acceleration is below the threshold for free fall. why is so?
  9. alexpanrui
    Feb 25, 2008
    32
    upz..............
