Looks very similar in operation to X10. Unfortunately, also appears very pricey considering everything the OP would like to do. Neat product though, I'll keep it in mind next time I'm thinking about moving a wall switch.No body here ever heard of illumra?
OP, attached is the final schematic and bill of materials (BOM). I think I covered everything in the right quantities, but hopefully someone will let me know if they see anything amiss. Note that the costs shown do not include things like shipping, taxes, consumables like wire, solder, etc., etc.
I've assumed you only want one button per room module and not three. Easy enough to add if needed though.
The design includes a bridge rectifier (D4-D7) which allows you to use any wall adapter rated 9-12VDC or VAC without worrying about polarity. I've also selected one of the most common plug dimensions used on these types of power supplies (2.1mm x 5.5mm). In the event one of your patients decides to chew through the power cord, you should be able to find a suitable replacement without trying to match it exactly.
Also attached is a picture of the enclosure I have in mind. It includes flanges on the side so you can easily mount it to a wall. It is light in color so I can more easily add labels (black on clear) to each module indicating which LED represents which room as shown in the drawing in my last post.
I'll shoot you a PM with a total cost and you can decide what direction you want to go.
