help: LED's with Auto dimming display
Discussion in 'The Projects Forum' started by thamer, Aug 15, 2012.
  1. thamer
    Aug 14, 2012
    i'm building a digitally based, analog display clock using LED's for the display. also, a microcontroller is used ( ATmaga168). i need the LED's to be Auto dimming (reduces the intensity
    of the LED display when the environment is darkened and restores
    brightness in normal light). actually im kinda lost at designing such circuit. should i use a photo resister? is it possible to use shift registor?? any idea will be useful. thanks in advance..
  2. wayneh
    Sep 9, 2010
    12,392
    3,246
    How are you controlling the current supplied to your LED display? Dimming is easy if you are using PWM control - you can just decrease the duty cycle and thus the average current and brightness.
    Detecting the light level is easy with any LDR (light dependent resistor). I usually see a CdS cell used for this, so I suppose that's the cheapest way to do it.
