Help: LCD interfacing using MPLAB
Discussion in 'Programmer's Corner' started by jon-eCe, Mar 2, 2013.
  1. jon-eCe
    Feb 23, 2013
    We are currently on LCD interfacing using PIC16f877A and MPLAB. Could someone give me any example source code for this just to get an idea how its done. Thank you. :)
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    Here are some LCD functions:
    Code ( (Unknown Language)):
    1.
    2. // LCD Interface
    3. // 4-bit Data on RB3-RB0
    4.
    5. #undef CLOCK32K
    6. #define FAST_CLOCK
    7.
    8. #define LCD_RS RA4
    9. #define LCD_RW RA3
    10. #define LCD_E  RA2
    11. #define LCD_Data PORTB
    12. #define LCD_TRIS TRISB
    13.
    14. #define NUL    0
    15. #define SPACE 32
    16.
    17. //-----------------------------------------------------------
    18. //                 Display Functions
    19. //------------------------------------------------------------
    20.
    21. void LCDrdy(void)
    22. {
    23. #ifdef FAST_CLOCK
    24.   char b;
    25.   // wait for LCD ready
    26.   // read data and wait for bit-7 = 0
    27.   LCD_TRIS = 0b00001111;
    28.   LCD_RS = 0;
    29.   LCD_RW = 1;
    30.   do
    31.    {
    32.      LCD_E = 1;
    33.      b = LCD_Data & 0x00001000;
    34.      LCD_E = 0;
    35.      LCD_E = 1;
    36.      LCD_E = 0;
    37.    } while (b != 0);
    38. #endif
    39. }
    40.
    41. void LCD(char b)
    42. {// send to data register
    43.  // send HI-byte, LO-byte
    44.   LCDrdy();
    45.   LCD_RS = 1;
    46.   LCD_RW = 0;
    47.   LCD_TRIS = 0b00000000;
    48.   LCD_Data = (b >> 4);
    49.   LCD_E = 1;
    50.   LCD_E = 0;
    51.   LCD_Data = b;
    52.   LCD_E = 1;
    53.   LCD_E = 0;
    54. }
    55.
    56. void LCDir(char b)
    57. {
    58.  // send to instruction register
    59.  // send HI-byte, LO-byte
    60.   LCDrdy();
    61.   LCD_RS = 0;
    62.   LCD_RW = 0;
    63.   LCD_TRIS = 0b00000000;
    64.   LCD_Data = (b >> 4);
    65.   LCD_E = 1;
    66.   LCD_E = 0;;
    67.   LCD_Data = b;
    68.   LCD_E = 1;
    69.   LCD_E = 0;
    70. }
    71.
    72. void LCDinit(void)
    73. {
    74. // initialize LCD for 4-bit mode
    75. // send $28, $06, $0C, $10
    76. #ifdef FAST_CLOCK
    77.   _delay(50000); // 50ms delay
    78. #endif
    79.   LCDir(0x28);
    80.   LCDir(0x28);
    81.   LCDir(0x06);
    82.   LCDir(0x0C);
    83.   LCDir(0x10);
    84. }
    85.
    86. void LCDclr(void)
    87. {
    88. // clear LCD
    89. // send $01
    90.   LCDir(0x01);
    91.   #ifdef FAST_CLOCK
    92.   _delay(2000); //2ms delay
    93.   #endif
    94. }
    95.
    96. void LCD_Line1(void)
    97. {
    98.   LCDir(0x80);
    99. }
    100.
    101. void LCD_Line2(void)
    102. {
    103.   LCDir(0xC0);
    104. }
    105.
    106. void LCD_Posn(int n)
    107. // position n = 0 to 79
    108. // Line 1 begins at n = 0
    109. // Line 2 begins at n = 40
    110. {
    111.   if (n < 40)
    112.    {
    113.      LCDir(0x80 + n);
    114.    }
    115.   else
    116.    {
    117.      LCDir(0x80 + n + 24);
    118.    }
    119. }
    120.
    121. void LCD_Txt(char *s)
    122. {
    123.   while (*s)
    124.    {
    125.      LCD(*s++);
    126.    };
    127. }
    128.
    129. // End of LCD functions
    130.
    131.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    Sure but you did not tell us if you are using assembler or C. And If C which compiler you are using
  4. bhodz
    Jan 29, 2013
    18
    hello do you have an idea on how to scroll the text in 2x16 lcd using 877a and mplab..pls help:( i want to scroll only the second line and make the first line steady..:( help.:(:(
  5. MrChips
    Oct 2, 2009
    12,624
    3,451
    Simply redraw the second line with all characters moved over by one position.
