help!!Its urgent!!
Discussion in 'Homework Help' started by waseemtariq, Dec 18, 2010.
  1. waseemtariq
    Dec 18, 2010
    My teacher has asked me to suugest 10 topics for project of digital logic circuits that does not use microcontroller....Plz help me i have with two days only..
    I will be very thankful to u...
    and one more question can i make a binary calculator without using microcontroller if yes, then hoe..
  2. JoeJester
    Apr 26, 2005
    3,393
    1,211
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    TTL Cookbook and the CMOS Cookbook are excellent references, but I don't think amazon can get them to you by Monday.
    You can also search this forum for keywords such as 7404, 7400, etc to find plenty of circuits.
  4. KMoffett
    Dec 19, 2007
    2,584
    234
    Google: digital project circuits
    Then try to keep it down to ten! ;)
    Ken
  5. tyblu
    Member
    Nov 29, 2010
    199
    16
    You can implement any logic circuit with discrete components (any one or combination of several of the following: gates, transistors, op amps, diodes, ... probably more, but that's all I can think of). A logic circuit can implement any simple task. Try to think of 10 simple things to do. If you cannot, I suggest Spoony Russian Roulette: press big red button, flip-flop debouncing, 555 advances linear feedback shift register for certain amount of time, output goes into hardware parity check which then either fires or does not launch a spoon (solenoid driver cct.) into the user's eyeball. A+!
