help is needed....
Discussion in 'The Projects Forum' started by axy_872000, Jan 13, 2010.
  1. axy_872000
    Jan 7, 2010
    11
    hello...
    i want to measure voltage using PIC 16f877a and interface with pc using max232 through labview 8.6..for measuring the voltage, i want to use ADC in the PIC 16F877a. the problem is, i don't know how to interface to pc using max 232 and is serial port D-sub 9 can be used?....is labview can read the signal send from max 232 or need to add something?....
  2. t06afre
    May 11, 2009
    5,939
    1,222
    The MAX232 is a rs232 level converter. So by using a PIC uC and the MAX232. You should in theory be able to do RS232 communication with a PC. I suggest you Google the term null modem.
    Then you can draw up a simple schematics, so we can check your plan out
  3. axy_872000
    Jan 7, 2010
    11
    i'm has finished draw the schematic..just simple schematic...
    however, when i try to simulate using proteus 7.1,the error has come out..
    the error is regarding with the dsub 9....it says that "no model is specified for J1" which is the dsub 9...do you what causing this error?...i don't put any program yet in the PIC...this the schematic....
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Ask yourself where the MAX232 supposed to get power from.
    Hmm?
    Then maybe you can figure out why Proteus is complaining about your DB9 connector having no properties.
    On the bright side, "help is needed...." is in the running for the "Most Useless Thread Title" award of the month.
  5. axy_872000
    Jan 7, 2010
    11
    i don't know...in the max232, the Vdd pin are hidden...ground pin also hidden...when i try to unhidden, it still remain same....
    hoho....i'm already change the title...hahaha
