Help interpreting a switch
matthew798
Joined Jan 16, 2013
38
Hey guys, I was hoping someone could clear up the function of this switch. I'm not too sure how to interpret what moves where when it is turned. It is a knob switch on the front of an amp
Joined Nov 30, 2010
18,224
My first impression was unprintable, and the more I look at it, the less it makes sense. The bigger picture, as requested by sheldons, is necessary.
#12
Joined Nov 30, 2010
18,224
The long horizontal dotted line represents a single shaft that connects 3 connectors that are short, vertical dotted lines. The short dotted lines connect circles on each side. There are 6 solid lines that you must ignore. The dotted lines actually should extend past the solid lines to get to the circles.
matthew798
Joined Jan 16, 2013
38
So if i understand correctly, turning the switch will change wich circle the DOTTED line is connected to? In total this knob has 3 connected wires at any 1 time?
