Help in VB6
Discussion in 'Programmer's Corner' started by YRAMR, Jul 14, 2010.
  1. YRAMR
    Jul 13, 2010
    hello everyone
    i am using vb6 to make a gui for a console application write in c++
    i am asking if i can call the exe of the c++ project and send to its main
    a string from textbox in form in vb6
    i can call the exe by sell function but i can't send to it any parameter
    shell(app.path & "\project.exe")
    can any one help me?
  2. BMorse
    Sep 26, 2009
    2,675
    234
  3. Harrington
    Dec 19, 2009
    86
    Using piped commands and redirecting pipedinputstream ,pipedoutputstream is part of answer to this You will more than likely need to implement threads
    Notes and examples can be obtained from here
    http://social.msdn.microsoft.com/Forums/en-US/vblanguage/thread/f27c5001-1eb0-455c-a3b5-78eab8a9d561
    Attached is one such example that I wrote In VB to show how you can use the stock standard output from ipConfig and capture the console output In VB GUI making the use of the tool far easier
    Eg from a dos command ipconfig / all using a piped command in dos
    ipconfig /all >> ip.txt capture the output using a pipe command and populates a text file with the ip configuration of your NIC
    I'm also attaching a Java implementation for you to show you how this done and the full Vb coding so that you can see that you will need to use Windows API calls to achieve this
