help in Thevenin's Theorem
Discussion in 'Homework Help' started by nonski, Feb 13, 2008.
  1. nonski
    Feb 13, 2008
    how do i determine the "load" resistor in a given circuit?
    please see this example
    http://www.allaboutcircuits.com/vol_1/chpt_10/8.html
    why did he chose the resistor parallel to the voltage sources as the "load" resistor.
    looking forward to your answers.thanks
  2. christian_sl
    Feb 13, 2008
    Load is chosen by yourself, which element of the circuit that you want to calculate its current/voltage using thevenin method.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    As has already been stated, the load resistor is that resistor in the circuit that is the object of your analysis. The load impedance is typically, though not always, an impedance that has one end referenced to ground.
    In the example circuit to which you linked, the author chose the 2 ohm resistor as the target of his analysis.
    hgmjr
