help in , sample and hold
Discussion in 'Homework Help' started by dakanat, Apr 19, 2009.
  1. dakanat
    Nov 12, 2008
    25
    hi
    if anyone has known about , sample and hold please give it to me...
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I know about them, but what are you expecting exactly?
  4. dakanat
    Nov 12, 2008
    25
    I did the experiment of sample and hold after that I lost how to write the Conclusion
    so if you explain it.Plz​
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  6. dakanat
    Nov 12, 2008
    25
    sorry i am not understand could you
    Summary it ​
  7. dakanat
    Nov 12, 2008
    25
    and the experiment was about analogue to digital converter.
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Possibly, you might find pages 4, 5, & 6 of the PDF on the AD585 interesting, as they bear directly on you query.
    Follow the link, get the PDF, read the PDF. You will learn everything you need to know.
  9. dakanat
    Nov 12, 2008
    25
    i ve read the PDF was more specifically, so jest i need general about it
  10. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You have a capacitor and a switch.
    When you close the switch the capacitor "samples" the input voltage.
    When you open the switch, the charge has no place to go and so the capacitor "holds" this voltage.
    Then the A/D converter may read this voltage at its own pace.
    The key features are how well does the capacitor follow the input, it is a low pass filter after all, and how fast does the voltage leak off after the switch is opened.
    Don't understand how you could do the experiment and lose the conclusion. I have confidence that according to the inscription on the silver chest:
    "Who chooseth me shall get as much as he deserves,"
