help in running light circuit
Discussion in 'Homework Help' started by fernnie, Apr 7, 2004.
  1. fernnie
    Apr 7, 2004
    I have a project names LED running light using poster, who gots the running light circuit?
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Can I ask what the running light circuit is?
  3. fernnie
    Apr 7, 2004
    Using LED to do the running light,when on power the light running on pattern
  4. mozikluv
    Jan 22, 2004
    1,437
    hi,
    you can try using CD4093 (quad 2 input NAND schmitt trigger) a source for clock pulse and a CD4017 (decade counter/divider) to drive your LEDs. it has 10 outputs.
    or if you want something a bit complicated try using the PIC16F84A. it can also directly drive 8 LEDs.
    there are lots of circuits of this kind in the web. a little patience will give you results.
