Help in powerline communication
Discussion in 'The Projects Forum' started by pastnine, Apr 8, 2012.
  1. pastnine
    Apr 8, 2012
    Goodday. I have been assigned the task of observing the modulated signal of a PLC modem, yet I haven’t been able to get started. I would like to request the board for assistance.
    What are good methods to go about this task? Should I use an Oscilloscope or Spectrum Analyzer? If so, Must there be a circuit between the measuring instrument and the power outlet where the PLC modem is connected, or is there a way to connect directly?
  2. studiot
    Nov 9, 2007
    5,005
    515
    I would start by reading the relevant standards.
    Google has plenty try: "Homeplug standards"
    Then you will need an rj45 breakout box to make your connections.
    A scope will show the the signal itself.
    A spectrum analyser will show the quality of the signal.
