Help in OPAMP "Integrator and Differentiator"
Discussion in 'Homework Help' started by Florida, Oct 15, 2010.
  1. Florida
    Oct 15, 2010
    Hi there :)
    I did a simulation for these OPAMs "giving in the in the Doc attached"
    and i got the graphs from my simulation and i was asked to prove that the output is indeed a scaled integral of the input for the OP AMP integrator, and to prove that the output is indeed a scaled derivative of the input for an OP AMP differentiator. So i don't really know how to prove it :confused:, so please take a look at the attached files of my simulations and the experiment paper and help me out here if you can :)
    Thank you Guys
  2. Kermit2
    Feb 5, 2010
    3,849
    965
    Do you know any Calculus? Basic Calc would be required to write a 'proof'. Will a graph be acceptable to the instructor?
  3. ELECTRONERD
    May 26, 2009
    1,146
    16
    The OP doesn't necessarily need calculus, complex algebra should serve as well.
