I need some help in math, ha ha ha . could some one explain the last line of this.Guess the " Letters" screwing me up as to what they mean.like RF = VFB and so on. i know the ma,stands for mill amps,and the ohms sign,
This is so i can use a STCS1 for a led driver.
tks
John
"""" quote"""
The current is set with an external sensing resistor connected to the FB pin. The feedback
voltage is 100 mV, then a low resistor value can be chosen reducing power dissipation. A
value between 1 mA and 1.5 A can be set according to the resistor value, the resulting
output current has a tolerance of ± 10 %.
For instance, should one need a 700 mA LEDs current, RF should be selected according to
the following equation:
RF = VFB / ILEDs = 100 mV / 700 mA = 142 mΩ
tks
John
"""" quote"""
