Help in IR sensor c programming coding
Discussion in 'Homework Help' started by Jackerq1, Nov 1, 2011.
  1. Jackerq1
    Nov 1, 2011
    Hi i am newbies in electronic field , i have the cousework that need to create a simple traffic light system by using the 5v infrared sensor with pic 16F628a.The problem is how i set the c programming coding for Ir sensor by using MBLAB. The how i determine ir sensor that is detected in logic "1".Your reply will appreciate .Thanks.
