Help in Common Mode voltage
WBahn
Joined Mar 31, 2012
30,062
What is it about their explanation that is causing confusion? In other words, how far can you get through their explanation before you hit a stumbling point?
rahul_electronics
Joined Dec 15, 2015
I am not sure how the amplitude and average length of the trapezoid is calculated.
Could you pl let me know how it is arrived? Thanks in advance :)
WBahn
Joined Mar 31, 2012
30,062
Recall that the definition of the common mode voltage is the average value of the two signals. If one of the signals is 0V, then that means that the average of the two is one-half of the other.
Does that help?
You can derive the waveform by simply using the definition. Add the two waveforms together and then divide by two to get the average.
