help in code plz
Discussion in 'Programmer's Corner' started by sangwooyasso, Dec 28, 2009.
  1. sangwooyasso
    Dec 28, 2009
    can any one tell me any information about fibunacci seies?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I am sure Google can. Have you tried searching the internet? Have you looked in a math textbook?
  3. Tahmid
    Jul 2, 2008
    344
    27
    Look here:
    http://en.wikipedia.org/wiki/Fibonacci_number
    Lets take a sequence starting from 1 and upto about 20 terms.
    The first number is 1, the next will be (1 + 0) = 1, the next will be 1 + 1 = 2, 1+2=3, 2+3 = 5, where the nth term is equal to the sum of the (n-1)th term and the (n-2)th term.
  4. Tahmid
    Jul 2, 2008
    344
    27
    Hi again,
    Here's a sample code in VB6:
    Code ( (Unknown Language)):
    1.
    2. Dim firstno As Integer
    3. Dim secondno As Integer
    4. Dim lastno As Integer
    5. Dim loopno As Integer
    6.
    7. Private Sub Command1_Click()
    8.     On Error GoTo ErrH
    9.     Me.Cls              'Clear form before printing anything
    10.     firstno = 1         'This is the number with which the series starts, dont
    11.                            'change
    12.     secondno = 1     'This is the number following, dont change
    13.     lastno = 22        'This is the last number to which to calculate the
    14.                            '     series. This is going to be greater than the last no.
    15.                            '     Change as desired
    16.     Print 0
    17.     Print firstno
    18.     Print secondno
    19.     Do
    20.         loopno = secondno
    21.         secondno = firstno + secondno
    22.         If secondno < lastno Then
    23.             firstno = loopno
    24.             Print secondno
    25.         End If
    26.     Loop Until secondno > lastno
    27. ErrH: 'In case there is some error in the loop
    28. End Sub
    29.
    Hope this clears things up.
  5. sangwooyasso
    Dec 28, 2009
    hi
    thank you tahmid you make it easy for me to understand this sequence
