Help in a 12 hours clock
Discussion in 'The Projects Forum' started by TulioTC, Aug 7, 2014.
  1. TulioTC
    Aug 7, 2014
    Hey, my name is Tulio. I'm 17 years old and atm i'm working on a 12 hours digital clock.
    Okay, I've used the 74LS93 to do divided by 10 and divided by 6 counters to build the seconds and minutes section and its working pretty well.
    To make the hours section I've based on this:
    Ok, its working well too but the problem is, it counts from 0 to 11 and reset to 0.
    I'd like some help to make it reset to 1 once the counter reaches 12. Someone suggested me to use JK flip-flops, I tried but failed, maybe cuz' i'm a beginner xD.
    Thanks in advance.
  2. ErnieM
    Apr 24, 2011
    7,433
    1,623
    The way I would do it is to change IC2 to a 74LS161 type which has a synchronous load input. That way on the 11th hour when the next clock pulse comes thru instead of just resetting to zero (undesirable) instead you can load 0001 and get the desired result.
  3. djsfantasi
    Apr 11, 2010
    2,899
    870
    Load 0000 after eleven or 0001 after twelve?
  4. MrChips
    Oct 2, 2009
    12,622
    3,451
    I would use two BCD counters such as 74LS160.
    Detect 12 and on the next clock pulse (synchronous LOAD) load 01.
  5. ErnieM
    Apr 24, 2011
    7,433
    1,623
    Ummm... yeah, that would be load 0 0001 (for 1) after 1 0010 or 12.
