Help in 3 questions -logic, PWM, and ADC
Discussion in 'Homework Help' started by yash_avengers, Dec 8, 2015.
  1. yash_avengers
    Sep 28, 2015
    15
    1.) Why are limit switches used to trigger the next state instead of just always using timers for everything? (Hint. What would happen if we used timers for everything and the air pressure dropped?)
    2.)How does the PWM output to the heater coil work?
    3.)How did you calculate measured temperature from the analog input ADC(1)?
    RRITESH KAKKAR likes this.
  2. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    Is for homework at school?
  3. yash_avengers
    Sep 28, 2015
    15
    Yes
    Mod edit: moved to Homework Help
  4. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    You will get more help here and ALSO if you ask questions that provide more detail. Attach any schematics, and what work you have done so far and you will likely get some help. As written, its hard to know what you are asking for and what help you need.
    Good luck!
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    You're kidding, right?
    You actually expect someone to tell YOU how YOU calculated something?
    Every question is looking for an answer that is specific to a particular set of tasks, probably performed as part of some lab. It appears you either didn't do the lab at all or let your partners do all the work, and now you want someone to provide the answers about things that you apparently didn't do.
  6. yash_avengers
    Sep 28, 2015
    15
    I am just looking for a theoretical answer.
  7. crutschow
    Mar 14, 2008
    13,505
    3,376
    Theoretically, I think you will fail this course. :rolleyes:
  8. BR-549
    Sep 22, 2013
    2,181
    420
    Maybe questions from a correspondence course?
  9. WBahn
    Mar 31, 2012
    18,087
    4,917
    You are looking for a "theoretical answer" to how YOU calculated some temperature using some microcontroller that had some ADC input?
    It's a gettin' deep!!
  10. shteii01
    Feb 19, 2010
    3,507
    512
