Help! I'm stuck trying to find the correct name for a male -> female receptacle
Discussion in 'The Projects Forum' started by laura2014, Dec 2, 2014.
  1. laura2014
    Dec 2, 2014
    Hello!
    So I'm in the process of trying to stock up on some electrical odds and ends and I'm stuck trying to buy one particular part as I'm not sure of the correct name.
    It is a un-insulated right angle part with a male tab on one end and a female receptacle on the other end. It is used inside of a switch when wiring film lights. I use them to adapt a straight receptacle to a right angle allowing it to fit onto the male tabs in the switch.
    Unfortunately when I search for them online it only comes up with two versions both with two male parts on each which aren't of use to me.
    I have attached a few photos for reference! Thanks so much, Laura
  2. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    They are commonly referred to as Spade or Stake-on terminals, Panduit are one of the larger manufacturers that you should be able to find a source, those are male to female adaptors.
    Max.
  3. Externet
    Nov 29, 2005
    781
    58
  4. #12
    Nov 30, 2010
    16,705
    7,358
    and again, max beats me to the answer. :p
  5. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    Looks like Panduit DV18 (or14)-250P-LY should be a replacement?
    (18g or 14g)
    Max.
  6. laura2014
    Dec 2, 2014
    Hello all,
    wow that was quick! Thank you all so much for your helpful answers :) I can happily order them now
    Much appreciated,
    Laura
  7. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    Miracles take a little longer!;)
    Max.
