Help IDing component
Discussion in 'General Electronics Chat' started by jptrsn, Jan 8, 2012.
  1. jptrsn
    May 3, 2008
    10
    Can anyone help me ID a component on a circuit board? It is the main board in an air exchanger, in position F3. The part is labelled F014. I think it is a fuse, because it is right next to where the main power supply is located, and there are two other identical components.
    The unit is non-functional, but I've made sure that the power supply works and the main fuse isn't burnt.
    Once I know what it is, I should be able to test and replace it if it is the actual problem. If it is a fuse, I believe the voltage (referenced to ground) should be the same on either side. I took a couple photos, and the unit is a Profilair VRC200.
    Thanks for any help!
    jptrsn
  2. tracecom
    Apr 16, 2010
    3,878
    1,396
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    I'll go with PTC fuse as well. Maybe 14 or 140mA, or 1 mA (using capacitor designation, but in microamps) unsure.
  4. sheldons
    Oct 26, 2011
    616
    101
