Ive had an issue of an electrolytic cap dropping its guts over my heater control board. Its caused the main transistor 2sd1525 to fail. After replacing the capacitor and transistor, cleaning the board off I re-fitted it back on the car. All was bueno until A day after, Where I got the same symptom. Fault code 'high starting current' I suspect the fan unit and a replacement is on its way to me. But it seems that the electrolyte has corroded a lot of the board, and in my OCD state, would prefer to renew some components or lift them to clean underneath to get the electrolyte, silkscreen off the board.
I cannot Identify the values of the diodes, Attached is the schematics kindly drawn up by another forum member who had issues with his.
The main ones are D2, D3, ZD1, and ZD2.
ZD2 is a 1AZ20, but I cannot find a supplier for that diode.
Any help would be greatly appreciated
