I need help identifying a couple of SMD components. I am trying to repair my USA SPEC PA11-HON iPod to Honda factory car stereo adapter box.
The first is a SMD transistor in a SOT-89 package with codes "HY" and either "628" or "725". The attached thumbnail shows the 725 but I believe they are interchangeable.
The second is a small 8-pin package, about 2.6mm x 1.6mm, with 4 pins on each long edge (sorry I don't know the code for this form factor) and the code "WG66". This component is part of an analog conditioning circuit and my guess is that it is either a resistor network or an amp, but I could be wrong here. Thumbnail is attached. Of course I do not have a schematic.
I have looked at several of the code deciphering sites listed in similar threads in this forum but so far no luck. Thanks in advance.
