Help Identifying SMD Component
radd
Joined Dec 6, 2015
7
just found this place, wish I had a long time ago, could have saved me some agro !
I am hoping someone may be able to help me identify this component, the best i have managed is that it is polarized, and 122K ohms
but unsure if it's a capacitor or diode. I'm only going by second hand info, it's a flight controller board for a drone.
panic mode
Joined Oct 10, 2011
2,749
hard to say, it is some sort of polarized component such as diode or electrolytic capacitor (although this is not likely due small size).
dl324
Joined Mar 30, 2015
16,918
A picture with sharper detail would help.
If this is for a drone, I don't think you should be modifying or repairing. Send it back to the manufacturer.
radd
Joined Dec 6, 2015
7
Thanks for the replies ! sorry don't have a better picture, board was professionally repaired, but the so called professional,
was supposed to resolder that chip and lost it :-(
I can't send it to the manufacturer as they don't repair their boards only replace them at 200 bucks.
If it helps any there are 3 etched lines on it as well
ian field
Joined Oct 27, 2012
6,536
My guess would be a diode - a chip tantalum capacitor is more likely to have an all numerical code like a resistor.
dl324
Joined Mar 30, 2015
16,918
Is the indicated part straddling the space to the pads below it?
Drones are in uncharted legal waters. Anyone repairing or modifying a drone could be held responsible for any harm caused by the drone; regardless of whether the repair or modification caused the problem.
The FAA says I can't shoot them down, but I believe very strongly that my right to privacy on my property usurps any poorly written law. Prisons in the US can't shoot down drones that are being used to deliver contraband to prisoners.
radd
Joined Dec 6, 2015
7
Thanks again guys !
@bertus, thanks will have a look!
@ dl324, it was soldered to the 2 pads Left - Right of it, the 2 smaller pads below were empty.
I can see you are not a drone fan, Sorry! your help is greatly appreciated though :)
If I could find someone with the same board, what test could I have them do to confirm the type/specs of the chip?
ian field
Joined Oct 27, 2012
6,536
Thanks again guys !
Look in the SMD code books.
Sometimes you'll find the same code repeated for several devices - usually identifying the type package will narrow it down.
radd
Joined Dec 6, 2015
7
Thanks for all your help, much appreciated :)
It seems to be the one that Bertus referenced ;-)
Would you agree that this would be correct:
ian field
Joined Oct 27, 2012
6,536
yep.. just a diode..
And shame on the "company" they didn't even include ref designators on the pcd.. amateurs :)
There are dozens of types of diode, with a screen print legend; a zener might have been given a ZD designation - but it rarely gets better than that.
SLK001
Joined Nov 29, 2011
1,549
On PCBs with dense SMD placements, reference designators take up too much board space. Even part outlines are sometimes left out due to space limitations. On boards that I used to work on, we had neither. The only indication that a part went somewhere was the exposed solder pads and resist opening.
radd
Joined Dec 6, 2015
7
Wow! thanks for all the info ;-)
Could I trouble you to help me with one other chip on the board it's above the 1002 resistor: Marked BR V
I'm guessing it may also be a diode, but looking through the code book ref's might it also be a transitor ?
Closest I could match it to is:
MMBZ5253B BR SOT-23
Thanx!
SLK001
Joined Nov 29, 2011
1,549
It appears to be a transistor. However, there is no standard for marking the SMDs from manufacturer to manufacturer. You'll have to search the manufacturer's web site looking for case markings, or pour through all the different spec sheets to find your device. It can be daunting.
radd
Joined Dec 6, 2015
7
Thanks! I agree, after a little more searching it seems more likely to be a transistor.
They don't like to make identifying smd's easy :-(
