Help identifying resistor
Discussion in 'General Electronics Chat' started by gtro127, Mar 14, 2016.
  1. gtro127
    Jan 19, 2016
    11
    Need help identifying this 5 band resistor. What threw me is the silver middle band which I can't find any charts that has silver as center band. BTW it is not Gray-definitely silver. Thanks for any response. IMG_9811.JPG
  2. #12
    Nov 30, 2010
    16,655
    7,294
    0.16 ohms, 5%
    Probably 2 watts.
    panic mode likes this.
  3. GopherT
    Nov 23, 2012
    6,297
    4,019
    what does your ohmmeter say?
  4. dl324
    Distinguished Member
    Mar 30, 2015
    3,371
    642
  5. GopherT
    Nov 23, 2012
    6,297
    4,019
  6. GopherT
    Nov 23, 2012
    6,297
    4,019
    I concur - except the red band is likely 50 ppm temp coefficient.
    #12 likes this.
  7. gtro127
    Jan 19, 2016
    11
  8. gtro127
    Jan 19, 2016
    11
    Resistor is open. Has crack on end which does not show in pic.
  9. gtro127
    Jan 19, 2016
    11
    Yes shiny silver.
  10. ian field
    Oct 27, 2012
    4,447
    791
    The value previously suggested is probably right - but if the old one is blown open, something caused that.
    You need to find out what failed short circuit.
  11. WBahn
    Mar 31, 2012
    18,071
    4,906
    How are you getting that since the diagram you are referencing only has a tempco band if the resistor has six bands.
    I know the TS is saying that the middle band is silver and not gray, but I've had resistors that looked like silver but turned out to be grey.
    Assuming it IS grey, then that would make it a 15.8 Ω, 2% resistor. This is a standard E96 and E192 value.
    I'm not aware of any coding scheme that would have silver as the middle of five bands.
    (EDIT: I mentally converted the blue band to green -- I should have gotten 16.8 Ω).
    panic mode and Marcus2012 like this.
  12. WBahn
    Mar 31, 2012
    18,071
    4,906
    Have you tried tracking down the schematic or talking to the manufacturer? A Google search of the model information may turn up something useful. You might also find a forum for that brand and get some help that way.
  13. gtro127
    Jan 19, 2016
    11
    It's open-has crack only visable with magnifier. Thanks everyone for replys.
  14. gtro127
    Jan 19, 2016
    11
    It's a playstation 4 power supply. ADP-200er are numbers from supply. I did google search with no hits on schematics.
  15. Marcus2012
    Member
    Feb 22, 2015
    349
    26
    16.8 Ohm 2% is what my money's on. I agree with WBahn in post 12, I've seen a few silvery greys and as far as I know gold and silver are exclusively for tolerance and multipliers. Might of just been a cheap way to save on paint to mark it as greyish as silver isn't used in that band.
    OR similar to #12s value it could be 0.016 ohms and use 2 multiplier bands? anyone seen this before?
  16. WBahn
    Mar 31, 2012
    18,071
    4,906
    Duh -- When I switched over to the tables I had in my mind brown-green-grey. Yes, brown-blue-grey would be 16.8 Ω, but 168 is not in the standard sequences. 169 is, which would make that band white. I've seen some silver/grey looking white bands in my time, but that one is a pretty large stretch.
    The good news is that it should be the least significant value band and so it shouldn't matter too much what it is, particularly with a 2% tolerance.
  17. gtro127
    Jan 19, 2016
    11
    Unfortunately roach feces was across to pins in secondary. Hoping it had just loaded down circuit to make resistor blow. Haven't found any obvious shorts. Hate to say it but every PS4 power supply I've worked on has had roaches in it. I usually order new supply's but this version is pricey and sells out quick when on ebay.
  18. bwilliams60
    Nov 18, 2012
    734
    94
    Silver in the third band is a multiplier of 0.01 which I believe makes #12 right. Gold would be the other choice in that area and would represent a multiplier of 0.1
  19. #12
    Nov 30, 2010
    16,655
    7,294
    Who did you think is on the inside of the PS4 competing with the player?:rolleyes:
  20. #12
    Nov 30, 2010
    16,655
    7,294
    Seems likely.
    I own some resistors with the first 4 bands. The fifth must mean something I am not familiar with.
