Hello all! I am new to the forums and am working on trying to rebuild/duplicate an older piece of equipment my grandfather made. I am trying to find a supplier for the meter movement that he used. (The original manufacturer has gone out of business) I am an electronics enthusiast/relatively new hobbyist so the depth of my knowledge is relatively shallow.
I do not have a lot of information to provide on the meter movement other than it's a "1 mil meter". (I was told the voltage cannot exceed 1 millivolt.)
The application is for a heat sensing indicator that uses two probes. If the temp from the left probe is higher than the right, the meter will swing to the left and vice versa.
An image of the meter is attached to this post. Any and all information is extremely appreciated.
