thanks for your post ,,, but it is different ...in second stage of my circuit diagram there both tr. are replaced by each otherhi,
This is a CD4050 buffer example, compare it with your diagram, what do you think.?
E
will you please help me understand this circuit a little more ..That is not a normal circuit, since the polarities of the first stage are opposite that of the second. If it works at all, it would be a digital inverter stage driving a complementary source-follower stage. I can't see where such a circuit would ever be used due to the offset in the output from the Vgs threshold voltages of the second stage MOSFETs.
by Jake Hertz
by Aaron Carman
by Jake Hertz
