Help identifying bracket manufacturer
Discussion in 'General Electronics Chat' started by tracecom, Jan 31, 2011.
  1. tracecom
    Thread Starter AAC Fanatic!
    Apr 16, 2010
    3,878
    1,396
    Attached is a photo of a plastic angle bracket that I bought from Budget Robotics. Budget Robotics has said they cannot get these on a guaranteed basis and I have advised them that I am going to try to locate the manufacturer. The photo includes the dimensions of the bracket. If anyone knows who the manufacturer is, or the identity of a distributor, I would appreciate that information. The brackets may have been used in the cabinet making industry.
    Thanks.
  2. tracecom
    Apr 16, 2010
    3,878
    1,396
    @PackratKing
    Thanks. Now I am even more certain that they are made in large quantities by somebody somewhere.
  3. kubeek
    Sep 20, 2005
    4,687
    805
    Probably three guys with a stove in China.
    You could search for some companies that make plastic molded stuff.
    ok i found something here http://www.sunyuta.com.tw/index.php...02709&sk=2007011601&item=&pro_id=201007160004
    and here http://www.alibaba.com/showroom/plastic-corner-brackets.html
    on google image search "corner brace plastic manufacturer"
  4. tracecom
    Apr 16, 2010
    3,878
    1,396
    I have tried Google and AliBaba with similar results to what you found, but I have not found the exact product. I will probably be buying only a few hundred at at time, and so I don't want to get into a tooling issue or other development efforts. I am really hoping to find someone with an inventory of these exact parts. Thanks.
  5. shortbus
    Sep 30, 2009
    4,088
    1,670
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    I still haven't found my dream connector/coupling...
    Electronic Enclosures
    I've seen them, but I haven't found where to buy them (or any anything similar).
  7. shortbus
    Sep 30, 2009
    4,088
    1,670
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    Thank you. I've bookmarked the page. The main reason I'm looking for the couplers is twofold, to be able to take it apart and to use metal, which is critical for heat sinking power projects.
    I'd done something similar with plastic over a decade ago. MEK has been classed as a carcinogen, so it can be hard to get in an industrial environment. You can buy it easily enough, but the safety guys can be a real pain sometimes.
  9. thatoneguy
    Feb 19, 2009
    6,357
    718
    Your Solution.
    Unless you wanted metal, then you'd need a mill.
  10. marshallf3
    Jul 26, 2010
    2,358
    201
    Hit up an Ace Hardware store, True Value or whoever and they'll have them in plastic.
    Sauder will probably send you a dozen or so for free if you just pay the postage.
