Interesting that the instrument shows an 'over-range' indication though (leaky NOS SMs are almost unheard of)... Absent a proper LCR indicator he needs to take your advice (i.e. measurement of several paralleled devices)...If it was 100 pf, it would cause a proper reading on a meter that has a lower limit of 10 pf...assuming the meter isn't broken, and Fluke has a good reputation.
You want the measured caps in parallel!I have the Fluke 111 meter. I'll try measuring in series.
Curious... They're not merely "resistors in cap's clothing" or the combined value should ~ 1.03I get 0.3 ohm for all 10 in parallel. I get 10.3 ohm for one single one. confirmed across a few different tests.
Yes! Of course -- I stand corrected! --- Maybe swering off java wasn't such a good idea after all (no offense Oracle )Bingo. They are 10 ohm resistors.
