Help identifying a resistor
Discussion in 'General Electronics Chat' started by pllasma, Jul 1, 2015.
  1. pllasma
    Jul 1, 2015
    5
    Hello all..
    I'm trying to identify a resistor, I kinda understand the color coding by this one is throwing me off a bit.
    Please view the attached photo. There appears to be red black red black lines.
    Thanks for any help..
  2. kubeek
    Sep 20, 2005
    4,686
    805
    they look like something between black, brown and red. It is really hard to guess from a photo. Also, have you tried measuring them?
  3. pllasma
    Jul 1, 2015
    5
    1.18 K-ohms is what I'm reading
  4. kubeek
    Sep 20, 2005
    4,686
    805
    That is measured out of circuit?
  5. pllasma
    Jul 1, 2015
    5
    They are still attached to the board. I measured each one separately. Not sure if that answers your question. I'm not really the best a voltmeters
  6. kubeek
    Sep 20, 2005
    4,686
    805
    The board looks like there are allways two connected in parallel. Try checking resistance between same ends and see what is connected to what. Or just desolder one end and measure resistance directly.
    My guess would be they are 2.1k but who knows.
  7. paulktreg
    Distinguished Member
    Jun 2, 2008
    621
    124
    It's hard to see the colours from the photograph.
    Try here.
    What are we looking here?
    Maybe someone can find a schematic?
  8. pllasma
    Jul 1, 2015
    5
  9. KJ6EAD
    Apr 30, 2011
    1,426
    363
    2.1k 1% probably.
  10. pllasma
    Jul 1, 2015
    5
    thanks.
    could you tell me how I read that with those colors?
  11. KJ6EAD
    Apr 30, 2011
    1,426
    363
    Red, brown, red for the value and brown for the tolerance. I said probably because the reds are barely more red than brown. As the red color oxidized and thermally decomposed, it bled into the surrounding ceramic coating. The brown stripes are still fairly crisp. Everything wants to turn to dirt but if it's already brown, no change is obvious. :rolleyes:
  12. dl324
    Mar 30, 2015
    3,369
    642
    My guess is 2.1K 5% for the 2 resistors on the left (red brown red gold); 1% would have another band.
    Can't make out the two on the right because there's a shadow from the wires.
    Note that the tolerance band on the resistor second from the right is on the bottom while the others are on the top.
  13. KJ6EAD
    Apr 30, 2011
    1,426
    363
    Not necessarily. Only if needed for more significant digits in the value; 2.05k or 2.13k for example. Values that end in a zero such as 2.10k are unique in that they can be represented with fewer stripes as the last (precision) digit is rolled into the multiplier.
  14. dl324
    Mar 30, 2015
    3,369
    642
    I stand corrected. As 2.1K isn't a standard 5% value, it must be 1%. That sucks; another exception to make things more difficult than they need to be...
  15. GopherT
    Nov 23, 2012
    6,297
    4,019
    image.jpg It says plain as day on the service manual...
  16. ian field
    Oct 27, 2012
    4,447
    791
    They look heat discoloured, so measurement may be your only hope - but if you measure them in situ; you are also measuring the parallel influence of various other circuit components. You can get a false low in situ that doesn't tell you anything useful - if you could identify the colour codes and then got higher readings than you should, you'd know they were faulty.
    Unless the design specifically requires that type of resistor, I'd identify the watts rating as well as the resistance and replace them with vitreous wire-wound - expensive, but they handle heat a lot better.
    There's some signs of heat discoloration on the PCB as well - those small electrolytics are awfully close, and they don't like heat even more than resistors.
