I have a "Cooling Fan Control Timer" (relay) from a 1978 Toyota that I'd love to repair than try and source a replacement for. The timer is pictured below with a closeup of the likely damaged components. My intro to EE class was in 1983 and my skills now consist of being able to use a multimeter. Any help would be greatly appreciated.
What I know: The module was made in Japan in 1978. It is from a 12V system and sits behind a 10A fuse. The only named component on the board is a cap with the "Nippon Chemi-Con" logo. The one burnt component appears to be a diode but the other - though appearing similar - has no marking to identify the cathode. Any ideas what I should purchase to replace these two parts? Thanks.
